dave w
I finished modifying a '7747 ECM for a Flash Chip using a ZIF socket ( http://www.moates.net/s4-aries-28pin-lowprofile-zif-p-46.html?cPath=26 ) $7.00. With this modification to the '7747 chip holder, a '7747 can use flash 27SF512 chips ( http://www.moates.net/c2-sst-27sf512-chip-p-39.html?cPath=26 ) $5.00 and these chips can be burned using the Moates.net Burn2 chip programmer ( http://www.moates.net/burn2-chip-programmer-p-197.html?cPath=94 ) $85.00. Soldering is REQUIRED!! Best thing about this modification is that everything fits under the chip cover!
dave w
dave w
Using an Ostrich 2.0 Emulator still requires de-soldering the old '7747 chip holder and soldering in a chip socket (
Older boards like the boards used in the '7747 can use leaded solder, which is easier to solder with because the leaded solder will flow at a lower temperature. The only challenging spot to solder on the '7747 chip socket are the ground pins, because the ground pins "wick away" heat. The ground pins in the '7747 chip socket are large traces and act like "heat sinks" when soldering. The ground pins on the '7747 require a fine balance of heat and time to solder, to much heat for to much time will burn the ground connection inside the board. Not enough heat for not enough time will create a "cold solder" joint and that's BAD!
