INChubbs29
Registered Member
Hi my name is Aaron, I am brand new to this forum but have read quite a few other pages to accumulate knowledge.
I currently own a 1991 GMC Jimmy SLX model with A.C. and the 350 engine. I have been working on the emissions, overall reliability and function of the truck. I have replaced all the vacuum lines that I know about, new mapsensor, new EGR control solenoid, and cleaned the EGR valve and passage way. It has a new distributor cap and rotor, new spark plugs, and I cleaned and rebuilt the fuel injectors. It has a new fuel pump, and filter. I recently checked the timing on the engine and it appears to be dead on, and the electronic advance working properly. The issue I am experiencing is a low idle stall, especially when I first switch to reverse. I am very uncertain about what could be causing the issue and have made little headway in a diagnosis. I have not yet ruled out other potential vacuum leaks or possible low fuel pressure slash volume. Any help or advice would be very much appreciated.
