321countryboy
Registered Member
so i had recently bought a 88 k1500 an i had installed a oil pressure gauge. it had low oil pressure around 10-15 or so. So i dropped the oil pan an replaced the oil screen an oil pump then i started it an it had higher oil pressure at about 40. Until i reved it then it droped back down to about 10 an now thats where it stays at unless i rev it then it will shoot up to bout 20 an when i turn the wheel it almost sounds like my truck wants to die an my oil pressure drops. anyone know what the problem may be thanks.
didn't line the bearing holes up properly.
