elks
So I have a lower ball joint heading out on my 72 blazer with the 44 front. I just replaced the ball joints last summer and have only about 4,000 miles on it since. The passenger side is good and the upper does not have any play at all...
So can I just replace the lower and be good? I believe I bought mogs before, but not sure... I can't find my paper and frankly I am a little pissed it is loose. Is it possible the nut on the lower was not tight enough? What is the torque spec there? Could I possible just tighten the nut and be good if it is loose?
Thanks a bunch.
Thanks a bunch.
