Lowest lift
blazerboy72
hiram ga
What is the smallest lift I have to have to fit 38.5" on my 72 without cutting? this is my daily driver so im not going to be off road very much
I'd say 6" suspension 3" body or straight 8" suspension. 8" will ride like crap and you will probably hate it on a daily driver.
you will rub with just 8 inch springs, i rubbed going in my driveway and over curbs, and my tires were 38 15.50 tsl radials.... just do some minor trimming and they wont rub.
it was superlift, which are stiffer then skyjackers, I had those same tires, and the same springs on my 77 with the bushwhacker cut out flares, and it still rubbed when i went wheelin.... Now im runnin about 5 inch lift and 39.5"s and with some good cutting i dont rub.... Are you nervous about cuttin on your rig? You can make cut fenders look better then stock fenders INMO, the best example is "yunit's" truck his fenders look F'in bad ass,
holy hell........ what did you do. i hope you dont have too many plans on wheeling it too hard.. unless you just got money to throw around.
i dont plan on wheeling it hard mainly just once a year. the body work was really about $2000 i exaterated a little /forums/images/graemlins/rolleyes.gif either way its too much to cut it
i dont plan on wheeling it i just want to have the biggest truck at school before graduation. i can always use the 73 or 74 if i want to go offroad
I have 38"(actual height) michelins on my 72 with a 4 inch lift and a bit of trimming, it could use a bit more, but where my fenders are so rotten, im just letting them rub. I like the low lift cause it keep the centre of gravity down closer to the gound. ill post a pic in a minute.
my aim is to have the biggest truck before graduation too /forums/images/graemlins/smile.gif. 36s with 7" would probably rub a little but nothing bad.
