LQ9 Oil Pan for 90 K5
Madbomber88
Mass
I am sure this has been answered, but I can't find it via a search. Doing an LQ9 conversion in my 91 K5. I'm using the ORD engine crossmember and motor mounts. Will the stock LQ9 oil pan work, or do I have to change it out? if I have to change it out, what have you used with success? I see the Holley 302-2 mentioned a lot, but not for this exact application. https://www.holley.com/products/engine/oil_pans/engine_swap_oil_pans/parts/VK090001
Any info is appreciated.
Our system should work with the stock pan but if you do run into a clearance problem (or have any other reason to change) just about any swap pan will give you a lot more room. The sheet metal Champ pan from Summit is a good one, or the holley cast pans are also good.
