Ls conversion and vacuum brakes
F-ingrob
Wheres the mud
san francisco ca.
Where are you guys getting vacuum for the brake booster from
I only see the port for the PVC valve in the driver side cover
I have mine in the back of the intake, it has a plug about a inch or so down. What intake manifold are you using?
yep back of intake near driver side its a quick connection plug . some are plugged off with a solid cap and others are hose barb . . . mine was snapped off and only reason i noticed it was i needed to solid plug it as i did hydroboost .
solid cap no vac to brakes :
vac port for brakes :
