LS Engine ECM Mount
MB5009
Just $29.99
The Motobilt LS Engine ECM Mount is laser cut and formed out of 14 gauge steel. The LS Engine ECM Mount allows you to mount your ECM in universal locations. Mount comes in two pieces that are approximately 2-5/8" tall and approximately 5" wide at the bases. The outside bolt holes are approximately 4" apart from center point to center point, and has a bolt hole in the center. Ships bare metal with no hardware, because it reuses the factory screws in the ECM.
MB5009
Just $29.99
