I recently replaced my leaky fuel rail connector (the tube that connects the two fuel rails together). The picture below still shows the old rusty one. Anyhow, since then my truck runs real rough, has a check engine light, and runs rich at the tail pipe. Autozone scanned my codes and it says I either have a vacuum leak or a faulty MAF sensor. Long story short, replacing the MAF didn't fix it, and I can't find a vacuum leak anywhere. Would pockets of air in the fuel rail connector tube cause this behavior in the engine? If so, how do you fix it?
