Everything I'm finding online says final torque for the exhaust manifold bolts should be 18ft-lbs. That seems really light to me. Is that correct?
Interesting. According to that the spec is 15ft-lbs with thread lock on it. Maybe this is in response to the fact that so many of these bolts break off when trying to remove them.
I just replaced all of the bolts with grade 10.5 so they should be good and strong but honestly I usually am looking up torque numbers to make sure I don't over-tighten. I used to crank things down way too tight and break bolts all of the time. I didn't realize just how over the top I was being until I bought a torque wrench and started looking up the numbers.Mine are certainly socked down tighter than that, but I have aluminum gaskets.
Honestly theyre a good n tight. As in use your judgement an go as tight as it feels comfortable. Theyre going to loosen up on heat cycle anyway and need to be re-tightened...
I'll go a little bit tighter than 18 though because I'd rather not use thread lock on them.
ALL fasteners have a proper torque, whether notated or not.... factors that change the range are diameter, materials of fasteners and components, thread type, length, etc...
