N NXT75 Registered Member Joined Apr 15, 2017 Posts 10 Reaction score 0 Aug 11, 2017 #1 Going to do an ls swap and use my 350 transmission any info for or against using the 350 transmission would be greatly appreciated thanks in advance
skunked phat block everything Premium GMOTM Winner Joined Feb 27, 2013 Posts 19,112 Reaction score 26,626 Location Placer County CA Aug 11, 2017 #2 What kind of "LS", HP & intended purpose?
N NXT75 Registered Member Joined Apr 15, 2017 Posts 10 Reaction score 0 Aug 11, 2017 #3 Stock L33 5.3 maybe cam upgrade for daily driver 75 jimmy
Justin V I should've stayed up there GMOTM Winner Joined Apr 17, 2016 Posts 5,759 Reaction score 8,566 Location Missouri Aug 11, 2017 #4 Need a cable throttle body for the kickdown cable. If you th350 is good, you'll be fine, plenty of high strung big blocks push through a th350
skunked phat block everything Premium GMOTM Winner Joined Feb 27, 2013 Posts 19,112 Reaction score 26,626 Location Placer County CA Aug 11, 2017 #5 No overdrive It's short so if you're running a short t-case (205) and a lift you can expect a pretty steep front driveshaft angle.
N NXT75 Registered Member Joined Apr 15, 2017 Posts 10 Reaction score 0 Aug 11, 2017 #6 skunked said: No overdrive It's short so if you're running a short t-case (205) and a lift you can expect a pretty steep front driveshaft angle. Click to expand... 4" lift trimmed fenders 35s original 350 I've had no issue with vibration
skunked phat block everything Premium GMOTM Winner Joined Feb 27, 2013 Posts 19,112 Reaction score 26,626 Location Placer County CA Aug 11, 2017 #7 NXT75 said: 4" lift trimmed fenders 35s original 350 I've had no issue with vibration Click to expand... just have to watch the angle when you droop the passenger side. You can always strap it if needed....
