So looking into an LS swap, but not the usual 4.8/5.3/6.0, but an 8.1 liter. I can get the complete motor, ECM, and harness for $500. I can get the Allison for an additional $250. Only problem with the tranny is the t-case, it's shot. Doing some research, only t-case available is one off an Allison. I want to run the 4L80, cheaper and easier to find. I think the swap itself should be fairly simple, since the 8.1 uses the same mounts as a regular big block, so wouldn't even have to change my mounts. But I'm sorta confused bout the truck wiring. I was told that the gauges work off the motor, and not always go thru the ECM. This would be going in a 99 Tahoe, so has to be a legal swap, for inspections and when they plug in the ALDL for codes and what not. I know DirtyLarry did this swap, gives the part numbers for everything, but since his is an older truck, not sure bout said gauges. Also, who has the best price and reputable service to do the ECM and harness? Since the wiring for the tranny's are different, either need to get a new one, $600 I think, or modify the stock. I'm sure I can rewire, but if not who is good place to do it? Also looked for this style swap on the net, but not finding much.
