So I plan on taking the cummins out of my k5 and putting an LQ4 and 4L80e and I just need some help identifying most of the big stuff I'll need. I bought the blazer in the beginning phases of the cummins swap
I am greenhorn to all of this so there may be some stupid questions
What I've got on the list:
The PO had already cut out the original cross member hence the ORD Crossmember on the list. The $325 version comes with motor mounts but I don't know if I could bolt the LS right to those mounts or if i have to get dirty dingo swap mounts.
I have read that the 91' K5's fuel pump is sufficient for an LS swap but I have also read that you need to use either of the pumps listed. Clarification with that would be heavily appreciated.
I think that's all the questions i have, thanks!
- ORD High Clearance Crossmember Big Block Version $190 ( $325 w/ motor mounts)
http://www.offroaddesign.com/catalog/enginecrossmember.htm
- Dirty Dingo LS R4 A/C Bracket Assembly $250
- Gauges from Dakota Digital VHX $750
- Dirty Dingo Chevrolet GMC Truck Blazer Suburban 73-87 4WD LS Engine Mounts $105
- Schoenfield 1302ls Headers?
- 97’ C3500 Fuel Pump Assembly or In-Tank Pump from 91’ Camaro with the 5.7
