When I swapped in my LQ9 I replaced the sending unit and put a walbro 255 in the tank. Fast forward to about 500 miles in and I run out of gas. Pump goes dead about 50 miles later.
I chalk this up to my dumb error but swap an AC Delco 62psi pump in. Now that one has gone bad. Started by just stalling while driving occasionally but now won't start and has left me stranded.
I pulled the pump and sending unit and noticed that the connector on the sending unit top (where the wiring terminates) to be charred from what looks like a short.
I replace the pump with another AC Delco under warranty and pull the charred connector out and wire positive and negative up directly. I have 12.4v at the pump and connectivity tests good all the way through.
But no priming and no pumping. Apart from a doa pump (unlikely) what else could I check? I know I am getting power but nothing happening.
At this point, apart from dropping a whole new assembly in (pump and sending unit) I am at a loss. I am also considering going to a higher end frame mounted pump as this is getting old real quick, but I like the security, protection and cooling of the in tank models
Thoughts?
Thoughts?
