Swapped an LQ9 into my K5 and have put about 500 miles on it with just the normal break in issues. In the last week it started acting funny during startup and would crank but not fire. Did it once and started the next try. Two days later wouldn't start and I check the wiring at the pump and grounds etc and it started
Then it wouldn't start at all and with relays firing for pump, I couldn't hear the pump priming on startup.
Thought I had a bad pump. I had ran out of gas and thought that I might have fried it. It was a Walbro high pressure pump for the LS motors.
Swapped out the pump for a AC Delco 62 PSI pump and still no go. The pump is priming but I have no pressure at the rail. The inline filter / regulator is clear but nothing.
Every tenth try it tries to fire, but doesn't. The PCM is seeing RPM so I don't think it is cam or crank sensor.
I am completely out of ideas and ready to burn the f$*#(# down.
