this is long, but bear with me..
DEMON44 said:
Would you care to share proof?
Thats something I'd need to see.
Here is some info on the issues with ULSD & the lubricity question..
Here's a thread on the NRC's issues with ULSD
http://coloradok5.com/forums/showthread.php?t=202729
Here's a bulletin from the canadian petroleum institute.. you may need to cut and paste into your browser, as it's a PDF.
www.cppi.ca/pdf/ULSD_Q&A_e.pdf
It talks about the need for a lubricity additive with ULSD, how the fuel suppliers ( not the refineries ) would be adding anything ( if at all), the kind of mileage hit you can expect, and implementation timelines..
This document does talk about a lubricity standard being in effect, however, according to the petroleum industry, there had never been a lubricity standard ASTM spec because the SLBOCLE & HFRR tests were considered to be "inaccurate, and of poor precision" for measuring lubricity..
you have to ask yourself, if the tests are the same as they were before, and the fuel has only gotten worse, why would the results now be considered valid when they weren't before? because somebody said they were?
For further reading - This was written before the 2005 "standard".. you guys tell me what changed:
http://www.chevron.com/products/prodserv/fuels/bulletin/diesel/L2_5_3_fs.htm
http://www.chevron.com/products/prodserv/fuels/bulletin/diesel/L2_5_2_fs.htm
here are some excerpts:
"Two laboratory lubricity tests have recently been standardized by ASTM: the Scuffing Load Ball-On-Cylinder Lubricity Evaluator method (SLBOCLE) and the High-Frequency Reciprocating Rig[/i] method (HFRR). These tests are relatively quick, inexpensive, and easy to perform."
"There was general agreement that lubricity is important and that an enhanced value, in some cases, would provide a functional benefit. However, a lubricity requirement for premium diesel was put on hold because the available test methods have poor precision and do not accurately predict performance for all fuel/additive combinations."
"ASTM has not yet included a lubricity specification in D 975 because:
The correlations among results of the two test methods and performance in fuel injection equipment needs further clarification.
In their current form, both tests methods do not properly rank all fuel/additive combinations..
The precision of both test methods is poor."
So, if anyone can point to an improvement in testing, I'm all ears..
And let's not forget that lubricity is not allowed to be a named "feature" of premium fuel,( why not, if it's inherent ) and people still lose injectors, suffer compression loss,and having their filters clog with yeast, fungus and bacteria..
furthermore, they still can't figure out how to make ULSD work in cold weather without using high sulfur kerosene as an antigel.. I posted up some pics of a clogged filter in the diesel forum, discussing this very issue..
http://coloradok5.com/forums/showthread.php?t=199194
As far as the the engine manufacturers or auto industry saying that there are no issues, I take that with a grain of salt.. their job is to sell more cars, trucks, and replacement engines..if they really felt that fuel wasn't an issue, their warranty information wouldn't say that they aren't responsible for damage caused by fuels of inadequate specification.. check out your caterpillar guide to fuels & oils, it's a very interesting read..
bottom line is that fuel specs vary, there's disagreement as far as what specification to measure and how to measure it, and what to do once it's measured, and the refineries and engine manufacturers all point fingers at each other when bad things happen.. and the poor guy with the the truck is at the mercy of everyone else.. that's where I come in..
