lSX on my engine?
Irishmic
Maine
Does anyone have any idea why on the bottom of the engine has LSX on it?
From what I understand the LSX engines were 454s. I also saw there were LSx engines made but were smaller.
I was told this was a top rebuild LS 5.3. Had it hooked up and told it was a 2003. It's a vortec engine, but I say that because of cover on top.
I know its not a 454. I have been trying to find ID numbers and such on it but nothing I find seems to lead me anyplace
From looking at it, I would say what you were told is correct. 5.3 LS truck motor.
The numbers you would need are on the back of the block I believe.
Okay, very helpful. I just was unsure and was worried it may be a bunch of different engines put together
Looks to be well installed, I wouldn’t worry at all if it runs well.
Looks like your iat sensor is not hooked up in the intake though?
Thabk you for pointing that out. With that not hooked up, what problems can I expect to happen?
Is this something I should get attached ASAP?
I can’t say for sure. It’s possible there is an iat sensor somewhere else. Does it have a check engine light anywhere? How does it run? How’s the gas mileage?
It does not even have a speedometer at all. The guy before changed the gagedash and messed it all up. No blinker lights, no lights for anything, I have RPMs, water (that i assume is engine temperature), volts, fuel. I have an oil gage but it does not work.
It runs good, when it's started the engine idles a bit high for 30 seconds or so and comes down. If I try and put it in reverse it can stall. Other then that the engine is sluggish but I'm told from a transmission guy I took it to probably the gearing. He suggested to put in a better torque converter. He said the transmission can be look at then to see how everything else is. But the engine itself seems to run good. Has 4k since rebuild.
