LTB 1993 bravada
REDCRO_REDNECK
mo
can anyone who has owned or does own let me know what you think about the vehicle and how reliable they are. is the awd system good? govt fuelecomy pages say they need premium gas, is that true.
all info will be appriciated.
They are good trucks. They are same thing as a S-10 Blazer with more bling. Milage you will get approx 15-18 city 20-22 highway.. Make sure trany cooler lines are dry very common for leaking and intake gaskets are very common for leaking, All in all good truck.
The interior is a bit more upscale than the Chevy/GMC version, but the t-case has no low range. Swapping in an NP-231 from an S-10 should be pretty easy, though I don't know if the driveshaft lengths would change. You'll also have to install the shifter and it's housing from the S-10.
REDCRO_REDNECK said:
anybody ever converted one to 4wd instead of the factory awd?
the winner of real truck last year was a bravada 60/14b, 241/300 doubler, tpi350
Yup cept it aint a bravada anymore.....
attachment.php
attachment.php
attachment.php
attachment.php
I had a '95 Bravo (as I call them) for a DD and it was reliable til the spider inside the intake dried up and cracked causing it to run like it misfired crazy.
