Lucas 15/40 high TBN oil
k5blazin
Elizabethtown, PA
Is anyone using this oil in their trucks?? do you think its necessary to use this oil or just use regular 15/40 with the lucas oil stabilizer??
I use regular 15W40. I'm not a beleiver in oil additives like Lucas. I seem to recall a test showing the lucas additive causing a lot of foaming...
Rene
While im not a firm believer in additives anyways, i do run the lucas oil additive. It doenst do much, but i run it anyway. Mostly because i tried it, and have been afraid of possible damage its caused and covering up, and figure if i put regular oil back in it i might put a rod through the block or something like that. So i keep running it :o
ok thanx for your help. i havent used the oil stabilizer in my new blazer yet, but i have used it in my 88 k5 and i did notice better oil pressure. i use it in my little "import" and its helped it get to the 194,000 miles that it has on it today. ill see how it runs without the additive for a little before i decide to use it.
