KS M1008 chassis
thatK30guy
1 ton status
Have an '86 M1008 rolling chassis with the 6.2, 400 and 208 still sitting in the rails. Everything was from a 4395 mile truck but had been sitting for quite some time so I'd recommend everything to be rebuilt or resealed/gasket. Motor spins easily but unknown condition as are the 400 and 208. D60 and 14FF have the usual 4.56 and Detroit in rear. However there is one missing lockout hub and the rear was missing a bearing hub/drum assembly so I slapped on a hub I had laying around. Everything spins and rolls easily. I will supply disc brake brackets if you buy the whole thing for $2500. I'm in central Kansas 67439 zip.
