M1008 Cucv Ls Swap Cadolet Build, long range Blazer Bash Project
Converting my M1008 from 6.2 Diesel to LQ9 power
If I wanted to get some replacement parts for my warn premium hubs where do I get them?
like this or are you needing something else?
I got the springs installed and the new shocks hooked up, tomorrow I'll put the hubs back together along with the breaks. and I have to wait on my 35 spline install but it will get done soon. Then I'll tie the front end back together and finish the shifter install. The shocks have way more extension than it did with a 5 inch lift. I know I'll lose some shock length once it's back on the tires.
Finishing up the front end and I am working on installing my tierod and we'll my hydro assist fittings hit my springs. How can I fix this or will it require zeusing stuff which I don't have the power of greyskull to do...
And the other question is the other end of the ram bolted on top of the tab or is it a double shear and it's in the middle?
Lowering that end could clear the fitting.
It's a double sheer I'm probably going to have to get some help on moving it
How is the cylinder anchor attached ? Can the ram beturned 90° and have fittings face forward?
90° AN elbow screwed into cylinder and a straight end on the hose should give enough clearance. Have to double check clearance at extreme travel of knuckles
I can turn the ram it has threads on both ends. I used field strip fittings from psc.
