M1008 Cucv Ls Swap Cadolet Build, long range Blazer Bash Project
Converting my M1008 from 6.2 Diesel to LQ9 power
Update to my Blazer Bash 2026 list.
Top Priority
35 spline swap spring of 27
Fix VSS with switch for low range. Fixed
Install FUSH spring of 27
Finish shifters set up. Adjust transmission and T case cables, install done.
Rear leaf spring shackles spring of 27
I Need to do
Exhaust leak, real exhaust
Power steering fluid leak at hydro boost
Oil Leak off back of engine (intake manifold needs to be pulled)
Make extra reservoir for PS fluid with rad hose
Secure fuel lines from tank to fire wall Mounts Ordered Mounts suck.
Gas Tank vent (where should I place it and what are some examples)
Lube Chassis
Fire Extinguisher
need to install
Fix O2 Sensor wire on passenger side and mount to fire wall New weather pack and parts here fixed enough, Fix for real?
Oil Leaks / any leak Fixed, I think
Fix steering brace on cross member.
Sending units for water and oil Bought need to install water temp Gauge cluster wire in and install.
find 37 inch spare tire
I Should do
Re cover seat in process Done
Torque Converter with cam install
Spare Battery
Clean up wiring in engine bay
Gas tank skin plate
Roll cage install
I would like to do
Stereo installed.
Pressure wash under side of truck
Intercom system
Cam swap
Horn Button install
Parts I need to bring
Oil Filter and Oil.
Spare Alternator ordered Killed in flood, re order
Spare AN line and fittings and tools.
Fuel line adapters to AN
Spare 50-1000 aem pump and fuel line and crimps new pump needed
gear oil
RTV
Gaskets for things.
Bedding for cabin
motor oil and filter
Transmission fluid
U joints for drive shafts acquired 1350's
spare hubs
Water
Engine Drive belt Ordered
Zip ties
water
tape
bailing wire
So I still have body lean, not as bad as before i changed the springs, so I'm now thinking body mounts are bad? what else could it be? I still need to install my new FUSH kit, that might be part of the problem with bad upper bushings on both sides.
you should be able to determine where the lean comes from - measure body points to ground F/R-L/R, and spring points to ground F/R-L/R. So 8 points total, look at the deltas...?
If i had a flat drive way lol , I gotta go find a parking lot.
Driver side front spring perch isn't collapsed or starting to? Saw one recently where a vehicle was leaning because of that.
Otherwise cab mounts, spring bushings etc.
I don't think it's that ill check. Not the best photo but you can see the lean on it.
Looks like your bumper is at an angle to the body, maybe exaggerating the lean-view from the front....?
Can you take pictures from the rear, keeping it PG :D
