M1008/K30 Frame
Damn. I'd take the whole frame off your hands if you weren't so far away. :(
Do you know if the upper mounts for the rear shocks can be used on a sub frame? If so, I would be interested in those plus the rear hangers.
Thats a perfect base for 2.5 ton Rockies.
Kenny--I'm interested in the extra frame braces--we're talking about the ones right behind the engine, with one brace longer than the other, right??
PM me
Jeff
To be honest I haven't even looked to see where they are exactly... but when I pull the motor this week I'll take some pics of that area. Should have what your after.
For anyone else who was looking at this I'm planning on using the bumpers, clevis brackets, springs, axles, and fuel tank sending unit. I've already pulled the TH400/208 and had it rebuilt and installed in my other truck. The motor is next to be pulled and rebuilt for my truck. I'm just looking to see if anyone wanted parts off of the bare frame before I cut it up.
The shock mounts just might work, but the spring hangers wont bc the 1 ton srw trucks have different spring perch width than any of the other gm 1/2 or 3/4 ton trucks/burbs.
Remington
Unless he is wanting the spring hangers to make it easier to install a 1 ton axle into a 1/2 or 3/4 ton burb...
Bingo! I have to move the rear hangers anyway for the 56's. What do you think the price shipped to 43162 would be?
cool well nvm, they will definitely work. I searched for a long time for hangers that would work, and actually found a pair on a drw 94 1 ton chevy 2wd, they were long and heavy duty, and were the exact width as my cucv hanger spacing fwiw.
Remington
