M1009 parts and civilian K5 parts
Ok, here are the pictures of the parts I've been asked about. My buddy is on a cruise with his girl and I don't know about the lower gun mounts.
Wire harness: I have one set of tail light harnesses (L & R) and two complete from fuse box back to tail light harnesses. One is slightly better than the other because it is virtually stock and other has had some taps in it for a trailer plug. Neither harness has complete black out light wires it looks like. The plugs where the harnesses connect are really clean on the untouched (no taps) harness with just a little light corrosion on the other.
Gun mounts: the upper mount is complete and the mounting bracket was carefully removed as it is straight. The spot welds left small holes in the bracket when it was removed. Both springs are working fine.
What trim pieces you looking for. For CUCV or civilian? I have some plastics from a civilian that was burgundy on the inside. That truck used off white plastics on the roof section and pillars. Have the door panels and seats for that truck too. Have white sunvisors I think too.
For CUCV I have the two kick panel vents, painted with orange municipal paint. Door panels.
NO dash pads.
Here is a bunch of pics of more stuff.
4 ares 10x15wheels w/BFG AT's 2 are really nice, 2 are older with a little dry cracking. All hold air fine. Wheels are useable but have some corrosion $150 The white on the tires is body filler dust because these tires were on my truck while the body was done and should clean up fairly well.
2 CUCV bumpers, front and rear. Some smallish dents but pretty straight $50pr
1 NIB aftermarket chrome frt bumper for 81-85. no rubber trim. chrome is OK but a little rough in some places. never mounted $75
1 OEM 87 chrome frt bumper w/rubber trim original used chrome is decent but needs polishing (no picture)
1pair of tinted OEM rear top sliders decent condition with no broken glass. One needs the center joiner screws drilled out and new ones put in. This is common problem and I can fix is someone wants the window. I will charge $25 to do the job. Windows are $75pair as is
Set of 4 CUCV steel 6 lug wheels for M1009, have worn rubber on them. $80 for set as is. If I need to remove tires I will charge actual fee charged me.
1 CUCV grille. Nice shape, one lower screw hole broken.
Sheet metal repair panels for GM. will work for pickup and blazer 2 sides, small lower fender piece, one inner fender panel for rear $50 for all
Pair of civilian power option door panels $10
Super nice OEM aluminum tailgate panel for fuel injected blazer gate NO dings and No dents. Can use a little polishing/cleaning but nothing bad at all $75
Pair of OEM SS mirrors that have been polished. Passenger side mirror has lost some reflective coating. $40
Will ship most, buyer pays all shipping. Local pickup is welcomed. Many other parts including red buckets and rear seat, white interior plastics for headliner/windshield pillar, etc., 3-4 cucv buckets, instrument clusters, some electrical harness, rear window manual regulators, etc. All stuff is cheap and I will be selling what I don't need.
Sorry about the tire size, thought I put it on there. Yes, 33 x 12.50 x 15's. You are looking for freight quote to the two zips? Washington? Probably a lot of money. I will try and figure it out but I would guess around $300-$400. Let me know.
Yes shipping would kill it. To bad though, thats a good deal. I really only need one, im sure i will find a good one local. Thanks!
Sorry, been away from this site for a while. Spring time chores and stuff. I have the set of mirror but noticed there is a drilled hole in the cover where the PO had a cb antenna wire coming out of. I can take a picture and show you. I think I only have one rear belt, not sure of the side. It is a belt from a M1009 but they are the same, you just need to paint it with interior paint. The other one is broken. I will get some pictures and send them to you.
Ted
