M1009 VIN decoder
K5dreamer
Alexandria, Va
How to decode your vin number:
1st digit = Nation of Origin
-- 1 = USA
2nd digit = company
-- G = General Motors
3rd digit = division
-- B = Chevrolet, incomplete example contract maintenance trucks
-- C = Chevy Truck
-- 8 = Multipurpose Vehicle All M1009's (blazers)
4th digit = GVWR/Brake System
-- E = 6001 - 7000 Hydraulic
-- F = 7001 - 8000
-- G = 8001 - 9000
-- H = 9001 - 10000
5th digit = Line Description & Chassis Type
-- C = 2 Wheel Drive 1981-86
-- K = 4 Wheel Drive 1981-86
-- D = military 4/4
6th digit = Series
-- 1 = 1/2 ton
-- 2 = 3/4 ton
-- 3 = 1 ton
7th digit = Body Type
-- 4 = 2 Door Cab
-- 8 = Blazer
8th digit = Engine Description
-- J = 6.2L V8 Diesel
9th digit = character is a check digit to verify VIN accuracy using a mathematical formula
10th digit = Model Year
-- B = 1981 F = 1985
-- C = 1982 G = 1986
-- D = 1983 H = 1987
-- E = 1984
11th digit = assembly plant
-- F = Flint
this was handy for me because of this......
What are the bumper height laws in the state of Virginia?
Section 46.2-1063 states:
Alteration of suspension system; bumper height limits; raising body above frame rail. -- No person shall drive on a public highway any motor vehicle registered as a passenger motor vehicle if it has been modified by alteration of its altitude from the ground to the extent that its bumpers, measured to any point on the lower edge of the main horizontal bumper bar, exclusive of any bumper guards, are not within the range of fourteen inches to twenty-two inches above the ground. Notwithstanding the foregoing provisions of this section, the range of bumper heights for motor vehicles bearing street rod license plates issued pursuant to § 46.2-747 shall be nine to twenty-two inches.
No vehicle shall be modified to cause the vehicle body or chassis to come in contact with the ground, expose the fuel tank to damage from collision, or cause the wheels to come in contact with the body under normal operation. No part of the original suspension system of a motor vehicle shall be disconnected to defeat the safe operation of its suspension system. However, nothing contained in this section shall prevent the installation of heavy duty equipment, including shock absorbers and overload springs. Nothing contained in this section shall prohibit the driving on a public highway of a motor vehicle with normal wear to the suspension system if such normal wear does not adversely affect the control of the vehicle.
No person shall drive on a public highway any motor vehicle registered as a truck if it has been modified by alteration of its altitude from the ground to the extent that its bumpers, measured to any point on the lower edge of the main horizontal bumper bar, exclusive of any bumper guards, do not fall within the limits specified herein for its gross vehicle weight rating category. The front bumper height of trucks whose gross vehicle weight ratings are 4,500 pounds or less shall be no less than 14 inches and no more than 28 inches, and their rear bumper height shall be no less than 14 inches and no more than 28 inches.
The front bumper height of trucks whose gross vehicle weight ratings are 4,501 pounds to 7,500 pounds shall be no less than 14 inches and no more than 29 inches, and their rear bumper height shall be no less than 14 inches and no more than 30 inches.
The front bumper height of trucks whose gross vehicle weight ratings are 7,501 pounds to 15,000 pounds shall be no less than 14 inches and no more than 30 inches, and their rear bumper height shall be no less than 14 inches and no more than 31 inches. Bumper height limitations contained in this section shall not apply to trucks with gross vehicle weight ratings in excess of 15,000 pounds. For the purpose of this section, "truck" includes pickup and panel trucks, and "gross vehicle weight ratings" means manufacturer's gross vehicle weight ratings established for that vehicle as indicated by a number, plate, sticker, decal, or other device affixed to the vehicle by its manufacturer.
In the absence of bumpers, and in cases where bumper heights have been lowered, height measurements under the foregoing provisions of this section shall be made to the bottom of the frame rail. However, if bumper heights have been raised, height measurements under the foregoing provisions of this section shall be made to the bottom of the main horizontal bumper bar.
I had a friend ask about me lifting the truck and if i would still pass inspection. i didnt have an answer. i do now :) somehow i think with just 4in lift and 38's ill be very safely within the letter of the law.
