The M101A2 is composed of an M101A2 cargo box mounted on the M116A2 Chassis, Trailer, 3/4 Ton 2 Wheel and the M101A3 is similarly built upon the M116A3 chassis. M-101 Trailer, Cargo, 3/4 ton Specifications Length, overall
147 inches
Length, cargo box
76 inches
Width, overall
73.5 inches
Width, cargo box
65.5 inches
Height
35 inches
Height w/cover
83 inches
Ground clearance
14 inches
Weight
1,340 lbs
Capacity
1,500 lbs
Note: Dimenstions are for the M101A2 variant.
Yes this trailer does tilt. There are two bolts that are in the front connecting the box to the tongue that need to be removed for it to tilt.
Remove the bolts, set the park brake, and puting your tow vechicle in reverse will tilt it.
