I've been meaning to join this forum for a while now, but I did it today out of frustration. I recently bought an '84 M1028 CUCV in what I thought was good, factory-condition. I knew these things had the 60 front and 14 bolt rear (90% of why I bought it), and my plans are to turn it into an off-road, camping/hunting truck. Anyway, I sourced a 4-inch lift from Offroad Design (rear shackle flip + front Tuff Country 4" HD springs) and in the process of installing it, I made a pretty frustrating discovery . . . someone stole the good axles out of this truck and replaced them with a 3/4 ton D44 front and 14 bolt rear. I'm really pissed at myself for not looking at the axles a little closer (I was more concerned with the body) but I just assumed they were the right ones. Lesson learned.
Anyway, that's my story, and now here's my question: I found and have acquired a set of M1008 axles with the factory 4:56 gears and rear Detroit, but have since found out that the 1 ton's had a wider spring perch spacing in the rear compared to the 1/2 or 3/4 ton's (42.5 compared to 40.5). The 3/4 ton 14 bolt I just removed has the 40.5 spacing and the new 1 ton unit has the 42.5 spacing. What I don't understand is that, when measured at the front or rear of the spring packs, it comes out to 40.5 from center-to-center? Am I missing something here? Shouldn't it be the wider 42.5 measurement? This is, without doubt, an M1028 truck, so I really confused with the spring-spacing measurement. Any insight would be immensely appreciated
