M1031 cucv ne pa
Backroads
NE Pennsylvania
1986 CUCV M1031
6.2/400/205
Dana 60/ 14 bolt
running/ driving/ registered. CARC camo. It is not perfect. Typical northest CUCV. Cab corners and rockers have rot. Exhaust has holes under cab. All of the generator system, pto, and its governor are here, but it doesn’t hold the engine RPM. I believe there is an electronic problem in the governor control module. A guy on steelsoldiers sells new governor modules. Drivers door window regulator does not work.
$3500
