MassMan
Well, my old hunk of junk is just a brake line install away from getting on the road (if nothing else breaks...), so I'm now concerned about the legality of the lift and lights (among other things).
We don't test emissions for older vehicles in Massachusetts, but there are strict laws regarding lift heights:
(edited out. I can supply the details if anyone's interested)
Source: General Laws of Massachusetts
www.mass.gov/legis/laws/mgl/gl-90-toc.htm
Anyway, how I read it, I should be able to calculate the maximum number of inches of suspension lift and inches of tire size above stock by a simple formula:
(wheelbase) x (wheel track) / 2200 =
measuring, I get a wheel track (center of tire to center of tire on same axle) of 79.6" and wheelbase of 106.5", making 3.85" of lift and extra tire legal on my truck.
the maximum height of the bottom of the door must be:
(factory door height) +(max lift)+(max tire)
and finally, the horizontal plane (whatever that is defined as) must be no more than 2" off of level front to back
My questions:
1.) How do I measure the lift on my truck? It was advertised as having a 4" lift, but who knows. It's got what look like 3 or 4" blocks on the rear.
2.) What size tires did these things come with? Should i go with the largest factory option or the base model size if they are different?
3.) Does anyone have a stock blazer's door bottom height?
4.) My front sags like crazy with the huge push bumper/grille guard the PO installed. How much of a forward rake did the blazers come with? Was the body line level?
5.) There is very little covering aux lighting in the code. I have some old tractor halogens as well as some cheep-o "off road lights". I don't plan on using them on the road, but I certainly don't have covers for them. I see jeeps running exposed roof light bars all the time, which is much more conspicuous than on the bumper like I want. Should I just chance it, install them to face down/backward when not in use, or just skip extra lights?
Sorry for the long post. The reality of living in Massachusetts is hitting me hard
My questions:
