The important mount is the one we send with the Magnum, the one under the adapter between the trans and Magnum is secondary.
Be careful tying the transfer case down too rigid, if it's more rigid than the motor mounts you run the risk of breaking transmission housings. Beyond that, even if the motor and transfer case are mounted rigid (but the same), if the chassis flexes around (i.e. especially square body GM trucks) you can break transmission housings. I really prefer a pair of mounts at the Magnum, same material and spaced about as far apart as the motor mounts.
If you want to add a second mount at the adapter between the trans and t-case, do a single mount in the middle so it supports weight but doesn't add any rigidity.
The extra torque makes it natural to want to add extra mounts, but too much is too much.
