hidesertwheelin
So what all is involves in making a dana 60 from a 2001 Dodge Ram 2500 fit my chevy? Just cut off all the arm brackets, find the angle, and weld on some spring perches?
you sure about that tdawg
an 01 dodge would have a crappy post 1994 3 piece axle on the pass side, driverside drop, unit bearings, ball joints not kingpins.
i am assuming that tom's truck has a dodge 60 pre 1994 with the pass side diff, kingpins, and selectable hubs.
if you did use the 01 axle you would need
new tcase $? unless doing sas in 3rd gen cgm
unit bearing conversion $1600
new 2 piece pass side axle $?
lotsa fab work for leafs $? unless you plan on putting a four link system in anyway which is still $?
this is why they are cheap
