general blaze
ok i have a 83 blazer with the 6.2 diesel and a 700r4 auto tranny
i am looking at buying a 86 chevy one ton 4x4 with a small block350 sm465 4spd manual trans and np205 tcase. Has dana 44 front, 14 bolt semi float rear with 4.88 gears, and open differentials.
i want to build my blazer useing the original 6.2 motor. and taking the the trans,tcase, and axels from the one ton. Is this going to be possible or am i in for a world of hurt. i figure i can use the pedal assembly and clutch master cylinders off the one ton as well.
what do you guys think. all info will be greatly appreciated
