chevysmithz71 said:Looks good!!Must be 52's up front.
Chrisblazzer89 said:
blazinzuk said:They are actually Dodge lift springs. Superlift 5.5" lift springs for a 94 Dodge half ton. They were free. A bit soft and the front is too high. They work dang good off road though.
86Cucvbeater said:How long are they? Did you have to move any mounts?
until I can get the knuckles cut and turned. blazinzuk said:In a word yes I had to move the mounts, both of them. The front hangers were easy. The rear was actually pretty easy too but created alot of other problems. The rears I used a aftermarket jeep hanger and put in below the frame. This resulted in great flex and a good amount of lift but really messes with the caster on the axle. I have to run huge shimsuntil I can get the knuckles cut and turned.
They are 60" long
