Gm is 587575 but still unreasonably expensive. I got half a mind to just put some spacers and call it a day.
I don’t know enough to say so but they said it would be ok by the specs.Are those exhaust-specific springs? I made a mistake before assuming that steel springs wouldn't be affected by heat. But by gosh I did ruin a spring under *300 in the oven. It was obviously not rated for the heat.
Mechanical Spring Issue: Relaxation at High Temperatures - Yost Superior
When mechanical springs are placed in high temperature environments they lose much of their strength and are subject to permanent deformation.www.yostsuperior.com
This is my only experience with these and the normal depth brass held very well and were also a mother to remove. So I got that going for me, which is nice.
