NEK5
3/4 ton status
Yep, Manny, sounds to me like you got the power to that CB off a non ignition port. In other words, its always on, with the ignition on or off. If that isn`t the case, then I would change the ground location for sure.
MuddinManny said:If the radio caused a drain through the fuse box being "hot" all the time, isn't going to the battery the same thing?
MuddinManny said:Thanks guys! I'm going to test light the fuse panel. I put the positive lead directly into an open accy slot like the instruction said. I think that it may be an issue. I will relocate the ground also. I will either locate the positive to a slot that is "off" when the key isn't in, or go directly to the "+" terminal. My question though is this. If the radio caused a drain through the fuse box being "hot" all the time, isn't going to the battery the same thing?
Manny
Klune-V is a underdrive that works like a dual case setup.SkysTheLimit said:My dad had a string of 3 bad optimas in a row. He bought 2 for his boat, they were both bad and so was 1 of the 2 replacements. Seems like a recurring trend with those batteries. They're great if you can find a good one.
