Manual Clutch and Body Lift?
skyyk5
N.E. PA
Has anyone had any troubles with a manual clutch and a 3" body lift? I might need to get the truck going fast. Would go hydro, But have all the linkage parts already.
I put a 3" on a K10 but I used threaded rod & an adjustable turnbuckle. I had to lengthen the hole in the floor pan for the clutch rod.
I couldn't go anymore than 2" or it would bind, and I also had to cut a slightly larger hole for the rod. But otherwise the linkage is stock...
