hmatiak
Just wanted to know how big of a switch, amp wise, are you running on your setup. Id rather ask than burn a few up trying to get it right. Thanks.
If all you are doing is energizing the relay which is the way to do it, you will not need much, if you are bypassing the relay then you will need a 50A which I believe is going to cost you a fortune.
I am bypassing the relay all together. Going from a hot 12v to the GP wire that breaks down to the individual plugs. Just putting a break (the switch) in the middle to control it.
