K5dreamer
Ok, so here's more thinking out loud. By now I've probably pounded my plan and end goal into everyones head. But heres the abreviated version.
I have an M1009 parts doner, complete. I want the 6.2 diesel, hydroboost, etc. out of it to swap into an earlier full convertible rig. Plan on a 6in lift, 1 ton axles, 37in tires on H1 beadlocks.
Here's the question. until now I've been hard set of a factory manual setup, because I didnt want to worry about that mess in addition to the diesel and brake system swap. But most of the rigs near me, that im finding in my price range, are automatics, but otherwise seem to be solid candidates, that meet my other requirements. (I seem to remember getting this advice from a helluva lot of y'all on here) Ive done some forum searching and not found an answer to this particular question.
How hard is a TH400 to manual swap really? Im sure a SM465 would be the cheapest/easiest option (keeping in mind the diesel/hydroboost part of the equation), but if I'm doing the swap should I go ahead and go full bore on a NV4500 if I'm going through the trouble? Or should I try to find an NV3500 for the better gear spacing? If I do a SM465 or NV4500 Ill do a NP205 TC, if i do a NV3500 Id use the NP208 out of the M1009.
I had no idea the price difference was that dramatic... sheesh.. and yeah, price is always an issue these days
The only concern I had was reading up years ago there were concerns with the strength of a 3500, with a 5000lbs rig, and big tires (obviously 37's arent big to everyone). so while the gear spacing is better, I always had that little thing in the back of my head saying eventually something would break.
With my tsls my truck gets wobbly above 55 anyways.
the crawl ratio with a SM465/205/4.10 setup is only marginally better (52.64:1) than the NV3500/208/4.88 setup (51:1), and is still buzzing above the optimal 1800rpm highway speed (1936rpm) at 52mph, not even 55mph (where its 2048rpm). When I seriously look at what I'm going to be using the rig for, driveability becomes more of a priority.
