Hi all! My son and I are putting a 465 manual in our 1988 blazer. We got the whole set up from a 1986 and later blazer-Including switches and clutch. We then got a new clutch, flywheel, clutch fork,pressure plate and throw out bearing (and pilot bearing). We installed the above parts and bell housing without the trans (easier to work on without it. Hole is in the floor, pedals installed, clutch master cylinder and slave cylinder installed. Hydraulic line is ready but not in yet.
I noticed now with all this installed the throw out bearing does not seem to line up with the center of the clutch. We used the alignment tool so the clutch is in the correct location. The bearing when in the fork is off to the drivers side. If I push the fork to the passenger side to center the bearing it pops off the ball stud.
I took it all apart and compared the new parts to the old parts (especially the clutch fork). All seem the same size and locations for the ball stud to hit both forks.
We are thinking to take the bell housing off and then putting the bell housing on the trans on our bench and then putting this all in at one time. Instead of bell housing first then trans.
Can anyone help with this? I will include pics. The pics are looking towards the front ot the truck from the back of the trans.
Thanks!
John
Thanks!
John
