78 GMC Jimmy
Anyone know what the lightest fluid that can be used in a 78 K5 manual trans? I switched from something heavy to something lighter and it helped a lot. How light can I go?
I would go synthetic 75w90Anyone know what the lightest fluid that can be used in a 78 K5 manual trans? I switched from something heavy to something lighter and it helped a lot. How light can I go?
Gm did use it when they combined the sm564 with NP208 but I had trouble with it.Would ATF be way too thin?
What issues did you have?Gm did use it when they combined the sm564 with NP208 but I had trouble with it.
It was also used because of fuel economy apparently
My transmission had too much wear for the mileage and had to much play.I had 80/90 and it was hard to shift into a gear. I put an additive in that helped a little (AT-205). Ran that for a bit. Drained the fluid and put in 3 quarts of 75W-90 Synthetic gear oil. I thought that would be enough, but it was not, so I topped it off with some of the 89/90 that I had just drained out. If I had to guess, I added 1 quart of the 80/90. I would like to improve the shifting more.
I have been running synthetic Dex6 in my sm465 for about 6 years without issues
If I was towing I may consider switching, but that oil is an equivalent spec to what the 4500 uses
Yes it does when coldDoes Dex6 improve the shifting for you, VS 75W90?
How much does it take?
The only advantage you will see is the synthetic fluid whatever you pick, because it doesn't thicken the same when cold.I think the only place you'll notice shift difference is when it's cold.
Mine seems to warm up enough in the first quarter mile or so (around freezing ambient) for shifting to get to "normal".
The difference between cold and barely warm is so stark, I don't see how lighter fluid would make an appreciable difference in how hard it is to get into gear, compared to after the spec'd fluid is warm. When cold, it simply won't go into gear without significant force. After that though, it takes little effort to shift.
Never tried anything else, so I'm open to learning, but if it was an amazing difference, I think it would be a lot more common.
Yes, but the oil has changed
It's Bruce Jenner juice!
