gregsenne
Registered Member
Im in the process of building my truck, and I took my SM465 transmission apart to see what it looked like inside. The transmission is the 3 speed with granny out of a 79 1 ton truck. When I got the transmission it didn't have any fluid in it because the guy said he drained it. It shifted well and spinned as expected. I took the top cover off and everything looked great inside, so I filled it to the right amount of fluid with 80w90, changed the seal on the input shaft bearing retainer, and put the top cover back on and bolted the np205 up. Then I noticed the input shaft difficult to turn, and the output shaft sometimes spinning when in neutral. Sometimes shifting to certain gears will lock the entire transmission. So I took top cover back off, and the problem still exists. It happens on both shift forks, and it seems like the gold rings get stuck. I'm not 100% sure everything I'm looking at inside the transmission, and I didn't take any gears out or mess with anything inside of it besides moving the shifters into and out of gears by hand. If I move them by hand now with the top cover back off, still having the problem.
Also, I know the 80w90 oil is thick, but it is incredibly harder to turn with fluid in it. If I grab the input shaft and spin in a few times around, my hands hurt from gripping it so hard (if that gives you an idea of how hard it is).
Thanks for any ideas. This is my first time looking inside a manual transmission.
