vortec
my dd has been running badly for a few weeks. slight miss at idle, nearly stalling just off idle, wimpy, and wants to stall anytime i give it more than about half throttle. no codes. i did all the normal fuel system stuff (filter, seafoam) with minimal change. O2, EGR, PCV, IAC ok. coil, dizzy, plugs and wires are all good. I'm down to ecm temp switch (about to replace temp gauge sender, too, but that's unrelated) or the MAP sensor. I know the MAP can go out of spec, but the computer doesn't throw codes as long as it's still getting some signal from it. so, i unhooked it to backprobe and the truck runs A LOT better, now. smooth idle, a little sluggish at low rpms, but knocks me back in the seat when i open it up. my air/fuel ratio gauge says it's just slightly on the rich side without the MAP which makes sense as far as the performance change.
before i blow $50 on the new MAP, I'd like to know if anyone can think of some hidden problem this would be masking.
vehicle is a '94 c1500 4.3L with 4L60e.
thanks.
EDIT: I finally got off work in time to make it to o'reilly, last night (i hate my job!!!). $50 bucks and about 2 minutes later, i had a major improvement. woohoo. I'll still give it a good basic tune-up before inspection (due this month) but it's nice to have it back in shape.
thanks.
