41565chevelle
Fellas, I need some electrical help...
I went ahead and did the fan swap last year. Purchased the Mark 8 fan from a member here, built a killer shroud on top of a 6.2l diesel radiator for my little 350. Fan motor just took a digger and I ordered a factory new one. Note; it is all wired with relays and has worked flawlessly since the install.
I get the shroud out, drill out the rivets holding the motor in, can't turn it by hand..thing is smoked. I install the new motor, lock nuts, reinstall the shroud and plug in the same plug I just removed.
The fan is all hooked up, go to jump the thermostatic switch and nothing!
I plug in the old motor, is jumps and stops, again its fried but I still get some reaction.
What gives? Could I have a bad motor out of the box? Just purchased at ORiellys for over a $100!
