I am currently working on the brakes on my burb and got a master cylinder from a 88 1 ton 4x4 crew cab. Being my burb is an 88 3/4 ton. Well I installed it and all just had to swap lines from front to back and noticed that where it bolts up to the booster the back part of the 1 ton master cylinder is a bit smaller than the 3/4 ton. Does it make a differance does it have to seal tight between the master cyl. and the booster.
Oh almost forgot I changed to a 1 ton master cyl. because I installed a d60 front and a 14 bolt rear with disc.
