On my 77 I got a 2 wheel drive master cylinder that leaks...I want to change it for a 76 2 wheel 3/4 ton cylinder that I have.
Will that work?
The reason I ask is because the 3/4 ton one has got reservoirs that are the same size front and back,the 1/2 ton cylinder has got a bigger res for the front brakes and smaller one for the back. Does that matter at all?
The truck has got a 10bolt in the front and a 12 bolt in the rear.
Will that work?
