evolve991
Resident Problem Child
Can I swap my plastic MC out with a cast MC? Will it bolt to the booster or do I need to switch out the whole thing?
I plan on replacing the JB5s and hoses when I upgrade the MC/Booster too. And if I decide to find a wider AAM 14SF with drums later on it will be enough to power the even bigger drums.I'm running 3/4 ton calipers on my front 8 lug ten bolt and 1/2 ton calipers on my rear ff 14 bolt. The 1/2 ton calipers have a slightly smaller piston. I have a summit racing disc/disc prop valve and the '83 p30 disc/disc master which I believe has a 4mm larger piston than my factory hydroboost master. It stops awesome with a good stiff pedal, which is what I like, and plenty of breaking power. I just need to add an adjustable prop valve to the rear circuit to take away a little pressure. The rear locks a little before the front and it needs to be the other way around with the front coming on first.
since my "buddies" always rigged stuff I paid them to do right and I've had to wing it or bug you guys about simple issues. Although I've owned dozens of GMs and a few lesser mechanical wonders this is my 1st and only ever 4WD and after 11 years owning it I'm still finding shortcuts and 'lowest price' nonsense in former repairs. I thank you guys for your advice,experience and speculations, that goes for everyone who's answered me in any post I've made. This Suburban is my Daily Beast and I'm too broke to have a muscle car ( Skylark) anymore so it's also the subject of my tinkering obsession
