Master mechanic contact info?
Richcz28
Vendor
Boston
Does anyone know if it's possible to get in touch with master mechanic? I have a screwdriver looking tool with a hook on the end instead for pulling pins or whatever else. The metal shaft decided to come flying out of the handle sending me toppling over. I can't seem to find a way to get ahold of them to see if I can get a new one through warranty.
Not that I should really want a new tool that flys apart, but I feel they owe me one.
Ah, ok thanks. I had no recollection of where it came from.
Cotter key puller?
Yep that is the guy. Thank you for the nomenclature.
a modern day version is also referred to as a hose puller.. Snappie now sells a set of 6 that I own, long and short...
I used to use cotter key pullers 25 yrs ago for doing windshield installs on the Mack trucks, still got a couple kicking around my screwdriver drawer... :pimp:
The hose hooks are a different shape though....or the standard ones are at least.
yup, but the other 3 are VERY similar to a cotter key puller.. they are 90ish, not 180 like that one..
here ya go...
as a marine guy I live by 5/16's nutdrivers and those... boats have eleventy thousand hoses and sharp evil clamps....
