Calvo
El Blazer
Hello everyone, I'm on to the next phase of my Blazer project and upgrading the axles. So, I'm selling both original GM Corporate 10 bolts, rear and front (passenger side drop). They have factory 3.73 with limited slip in the rear. Currently, they're waiting to be removed but I expect them to be ready for pick up by end of October. Back in March of 2021 both axles were pulled out, cleaned up, and painted when a new suspension was installed. I also had 14mm 1.5 thick lug nut wheel studs installed (still 6x5.5 chevy pattern), and up front I replaced the original knuckles with new ones from Reid Racing, and the U and ball joints up were replaced then too. An ORD Dana 44 crossover steering arm - right hand side - will remain installed on the passenger side, as seen in the photos. Note that the rear axle shock mounts are from DIY4x's inboard shock kit. These two axles will be housed nicely at Tucson Differential in Tucson, Arizona. Open to ideas and offers. Asking $1300 for the pair. Oh! and I'll have a pair of overload "add a leafs" from BDS that'll add approximately 1.5" to go with them for the rear leaves. Thanks for looking!
