Ned Kelly
Which factory rad would provide the best cooling capacity? I'm currently running a 454 rad with my BBC but it's 20yrs old and it's looking like time to replace it.
I had the upper neck cut off and changed to the 454 hose size and used a OE 454 hose.
The lower neck is huge so I cut about 3" off the water pump end of a 454 hose, slid it onto the pump and then used the 6.2 hose which fit over the bushing perfectly. Everything fit nice and tight with no leaks.
I probably would have had a new, correct size lower neck put on too but the rad shop was bitching about the age of the rad and such so I did the minimal and had it cleaned and the one neck done. It was an extremely clean low mileage rad from a CUCV so, imo, it was fine. I think he just wanted to try and sell a rad.
