MaxPF
Well, I managed to get an NOS GM 6.5 crank for $300. A brand new AMG/GEP crank will set you back about $500-$600. These are the only ones I would buy. AMG is American General, the company that manufactures the HMMWV for the military. GEP is AMG's General Engine Products division, which manufactures brand new 6.5's for use in the HMMWV's, as well as replacement engines. If you buy a Goodwrench 6.5, you are getting a GEP engine. The blocks, heads, and cranks are cast by International Truck and Engine, the same folks who make the Powerstroke, DT466, etc. These cranks are every bit as good as the GM cranks were (the blocks and heads are far better - too bad you can' buy em as seperate pieces like you can the crank. The only way to get a GEP block and heads is to spring for a long block). Any other crank you find will be Chinese in origin. A guy over at the Diesel Page bought one (which was advertised as a forged crank, even though it was obviously cast), and it broke in shipping!!! The material looked like gray cast iron, not nodular iron. You could have dropped a GM crank from an airplane and it wouldn't have broken. Breaking a crank due to mishandling is impossible, unless the material is horribly substandard. You will see these often on Ebay. Unless it is advertised as a GM crank (or possibly GEP crank) and you can verify it (i.e. casting numbers), you can be certain it is Chinese. Scat also has a 6.5 crank in their catalog. It is supposedly a "cast steel", although Scat's cast steels are actually a nodular cast iron. I don't know what the casting quality is like, but I do know that it does NOT have rolled fillets. Rolled fillets nearly double the fatigue resistance of the crank, and they increase the amount of bending the crank can handle before it even begins to fatigue. Rolled fillets are a necessity on cast diesel cranks. They simply won't have a long lifetime otherwise.4x4_76 said:So, how much did that new crank cost? I've been looking in my garage and searching crank that was removed from the block that's under the worktable. So far no luck finding it. I remember it having one bad journal, so wouldn't been any good to use.
Well, as a general rule if the block is cracked it is scrap iron. There has been a couple folks who had 6.5 blocks with cracks that didn't extend beyond the bottom of the outer main bolt holes. They stop-drilled the cracks and installed splayed main caps, and haven't had any problems even though they are bombed fairly well. Note that they did NOT use the outer main cap bolt holes -with the splayed caps you drill and tap new holes at an angle that extend under the pan rail. This is the strongest part of the block. While I believe they won't have any problems with their motors, their success hinges on making sure that they intercepted the bottom of the cracks with the stop-drill. Otherwise the crack could continue to spread. It is definitely not something to try unless you (or your machinist) really know what they are doing and are willing to live with the consequences if it fails.Also that block has cracked webs. Don't remember how badly. But after reading this thread couple of times, I started to wonder that if I buy main stud kit and fab full main girdle, could I use that block? What I've heard, crack free blocks are hard to find in here.
Do you have a 6.5, or a 6.2? Most cracked blocks I have heard of are 6.5's, especially the 97-2000 blocks with the piston oil sprayers in the main webs. Earlier 6.2's have thinner main webs than the later ones. I would reccomend that you keep looking for a good buildable block. They're out there.
I'm thinking of replacing them with something trick.
Can you say "low friction"?
and where is that drool smiley?
